changing slider description for different slider images
Discussion in 'Squirrel WordPress Theme' started by evancohenshikora, Feb 1, 2016.
  1. evancohenshikora
    evancohenshikora New Member
    Is there a way to change the slider description depending on which picture is in the slider? (so the description would change as the picture changes)
    That will be possible with source code customization in the theme and that will chargeable as well..
    Do let me know if you agree then, I will tell you the amount and mode of payment.
