changing slider speed in Golden Eagle - What and Where is the JS directory?
Discussion in 'GoldenEagle WordPress Theme' started by ebandflow, Jun 5, 2013.
  1. ebandflow
    ebandflow New Member
    I saw in another post that to change the speed of the slider one must go to the JS directory and change the value of the play speed. I am unable to locate the js directory does anyone know where this is located?
  2. ebandflow
    Not sure what FTP stands for either. Also, where can subfolders be found?
  3. Nitesh
    File transfer protocol is a standard for the exchange of program and data files across a network.
    Please contact to your service provider they will provide you FTP login detail. Through which you can login to your WordPress and theme files.
  4. ebandflow
    Thank you for your reply.
    I am still uncertain as to how to go about changing the slider speed.
    Where is the js directory located? Is it in the editor?
  5. Piyush
    Please do let us know about the speed of the slider and in what time duration (in seconds) you want to slide the images.
    We will edit the theme according to your requirement and send it to you.
  6. ebandflow
    Thank you very much for offering. 4 seconds would be perfect. Also, is it possible for the slider to fade? Thanks again!
  7. Piyush
