Changing slider speed
Discussion in 'Themia WordPress Theme' started by gowebsol, Dec 23, 2014.
  1. gowebsol
    gowebsol New Member
    Tucson, Arizona
    Help! I need to change the speed of the slider. Where do I go to do this please?
    Joey
  2. Pramod
    Pramod Guest
    Please follow below image.
    Pramod
  3. gowebsol
    gowebsol New Member
    Tucson, Arizona
    Perfect, thank you. You may want to suggest using a theme editor next time. I was confused how you were able to see the file to edit through the regular code editor, but eventually figured out I needed a theme editor plugin. Which one do you use? Is it compatible with child themes?
    Thanks very much for the fast reply and help!
    Joey
  4. Pramod
    Pramod Guest
    Hello Joey,
    Yes i am using WP editor plugin and it is compatible with child theme.
    Pramod
