1. Hi. How do I change the text in the search box that says: "what are you looking for?" 2. How do I change the text that says "Classi Craft" at the top of the site? 3. How do I change where it says: "Blog" and "innovation" ? 4. I changed the site title and tagline. Where does this appear? I don't see it appear anywhere Thank you
I think I see the answer to number 3. Looks like the answer to change "blog" and "innovation" is on the "Classified Categories" page. Is this correct?
Hello, 1) For this go to the classicrafttheme\library\text_domains\template_path.php And change text as shown in the image. 2) I think you are talking about logo. You can add your own from Dashboard > Settings > Theme options > General settings > Logo 3) Yes you are correct. These are "Classified Categories". 4) It will display at the browser tab while hover. Thanks & Regards Nitesh Raghuwanshi
Thank you. Also, how many letters / characters can #1 be? I do not want to break button. I want to change "what are you looking for"
Hello, You can add the text that comes in the max-width of 200px. Thanks & Regards Gourav Shrivastava
