Changing the Slider Speed
Discussion in 'GoldenEagle WordPress Theme' started by amyberkhoudt, Mar 7, 2013.
  1. amyberkhoudt
    amyberkhoudt New Member
    I'm really new to this and I'm trying to change the slider speed on my Golden Eagle theme. I see that you are telling most people to look at something called Js in their theme options. Could you give me a step by step on how to find this page?
    Thank you!
    amy
    Go to
    Js > Custom.js
    present in theme directory and adjust the value of play by increasing the value the slider speed decreases,and by decreasing the value the slider speed increases .
    You will not get theme directory in your dashboard.
    You can edit custom.js file through FTP.
    Open your Theme directory (through FTP) > js
    Download custom.js file from there, Edit it, Then again upload it.
  3. ebandflow
    ebandflow New Member
    what is FTP?
  4. Nitesh
    File transfer protocol is a standard for the exchange of program and data files across a network.
    Please contact to your service provider they will provide you FTP login detail. Through which you can login to your WordPress and theme files.
