How would I change the themes color to my choice? Go to Appearance > Theme Option > Styling Option > Theme Stylesheet and select your color scheme from there.
Go to Appearance > Theme Option > Styling Option > Theme Stylesheet and select blue color scheme from there. And then go to the color directory (Theme directory -> css directory -> color directory) present in your Theme directory and edit the blue.css file as shown in the image given below. This will solve your issue.
The whole replacing the images has me very confused, i was able to go into the ftp and see where the images are and i am able to understand where they are placed in the coding. I just need more clarification on what I need to replace to make it the colors i want.
Hello Pupwild, Some color are displaying with the help of images on the background in this theme. For the reference see the image given below So if you want to change that color-image of the Theme then you would need to replace that images with your custom color images having the same name as previous images, from the images folder present in your theme directory (Theme directory -> css directory -> color directory -> images folder). You can use Photoshop to create your custom color images. Note: Your custom color images having the same name as previous images and having tha same dimension.
So pretty much what I am doing is taking the picture file and putting a new color over it in photoshop, then reuploading it to the server?
