Changing title for comments
Discussion in 'Andrina WordPress Theme' started by kbrad613, Sep 16, 2015.
  1. kbrad613
    kbrad613 Member
    The comments section at the bottom of each post currently says "Please leave reply." It's so generic. Can I change it? If so, how?
    Thanks so much.
    You can resolve your issue with the given code below and you just all have to follow the steps as shown in the screenshot.
    Code is:
    <div id="comment-form">
      <?php $args = array('title_reply'=>'Leave a test comment');
        comment_form( $args); ?>
    </div>
    Note: Replace 'Leave a test comment' with your desired text in the code.
    Inkthemes.com
  3. kbrad613
    kbrad613 Member
    Thank you Priyanka! It worked perfectly! :p
