ClassiCraft not working with Adblock Plus
Discussion in 'ClassiCraft WordPress Theme' started by spottedvarennes, Feb 14, 2015.
  1. spottedvarennes
    spottedvarennes Member
    Hi, Classicraft display a blank page when adBLock plus is ON, and when navigating to an AD, I think it block it because of the word AD in the Url. Do you have a solution to change the URL ? To change the word AD by somthing else ?
  2. Naveen
    Hey!
    I don't thing so because, Ad Block is installed on my browser too...
    It seems to some plugins are conflicting in your WordPress, please check your plugins,
    Kindly deactivate all plugins and see the result, then activate your plugins one by one by seeing result on each activation...
    Hope you will figure it out..
    Naveen Kolhe
  3. shyheim
    shyheim Member
    the problem is "single-ad" on tag body, i put only <body> on header.php and it works
  4. spottedvarennes
    Naveen I tested your Live preview, it does the exact same think with adBlock plus enabled
  5. spottedvarennes
    Can you explain what you mean ?
  6. shyheim
    shyheim Member
  7. spottedvarennes
    yep you are right, the single ad class trigger the adblock thanks, how you found this ? does adblock told you what it blocked ? mine doesnt tell me what it block
  8. shyheim
    shyheim Member
    i dont remember.. maybe i've found "single-ad" on some adblock's blacklist.. now tell me how to fix my problem.. :D :D :D
  9. spottedvarennes
    Thanks you again shyheim you saved me hours of works
  10. spottedvarennes
    For the other problem you had, you'll have to change some javascript, and some code in files, kind of hard to tell you exactly what to do, since my solution works on my customization, but yeah I can help you by skype, PM me your skype I'll try to help
  11. spottedvarennes
    So to fix this add this function in the functions.php of the theme
    function remove_a_body_class($wp_classes) {
          foreach($wp_classes as $key => $value) {
          if ($value == 'single-ad') unset($wp_classes[$key]);
    return $wp_classes;
    add_filter('body_class', 'remove_a_body_class', 20, 2);
    This will remove the single-ad class from the body. Everywhere, this class not seem to be used in any css or javascript, so it should be safe to remove. Ill let you know if I found a bug because the single-ad class is removed.
  12. shyheim
    shyheim Member
    mmmmhhh seems doesnt work for me..
  13. spottedvarennes
    Hi I updated the code, forgot the filter ;)
  14. spottedvarennes
    Please we need confirmation that the single-ad class can be removed from the body class. . I see no css attached to this class, and it trigger Addblock so it should be removed if not used elsewhere in the code. Please see solution I gave for a quick fix
  15. shyheim
    shyheim Member
    yes it works !
