Hi another quick question, with the old colorway we also had a mobile version of the site - that has now gone in favor of the better responsive colorway - however on the old mobile version of the site www.skbtaxis.co.uk there was a tap or click to call button which the client and customers liked - is there a way to use this plugin in http://wordpress.org/plugins/call-now-button/ or do you have a code snippet which could be put on the home or contact form page which would only show up for smart phone users to create a call now link Thanks Sam
Hello, You can add tap to call feature in the contact form page. Just add code given below. Code: <div class="call">Tap to call</div><a href="tel:11111"> 1111</a> After that paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .call{ display:none; } @media only screen and (max-width: 480px){ .call{ display:run-in; } } @media only screen and (max-width: 960px) and (min-width: 768px){ .call{ display:run-in; } }
Hi There - Thank you for the code snippet - it does work, but is also showing up on PC screen? ( I have refreshed cache ) any idea why? Also is there also a way of incorporating it near the top of the home page? great service as always Sam
Hello, I have checked your site. You have not added first code correctly. Add complete code inside class "call" as format posted above. Check image for reference.
Thank you for checking the code so well for me - other part of the question was can this code be incorporated on to the home page or in side bars thanks Sam
Hello, You can use same code for footer and sidebar widget area. Just add same code in the text widget.
