Click Pic for next page
Discussion in 'BusinessGrow One Page WordPress Theme' started by rsjhunter, Apr 25, 2014.
  1. rsjhunter
    rsjhunter Member
    zerochlorine.com
    on home page if you go to Ecosmarte and many people tell me they click on picture and nothing happens they don't realize to click on pools & spa for next page.
    anyway to add link to pic also?
    Anyway to add a drop down menu to front page?
    Adding link to the pic will affect it's designing effect. You can change color of heading with the help of code given below. So that it will look different from other content and users will click on it.
    .rect_box .services_box_rect_head a{
    color:YOUR COLOR VALUE;
    It is not possible to add dropdown at the front page. You can create custom menu and add them in the footer widget area.
    Nitesh Raghuwanshi
  3. rsjhunter
    rsjhunter Member
    Do you have anexample website of menu in the footer widget area
    and How would i go about doing this?
    zerochlorine.com
  4. Gourav
    Go to Appearance > Widgets
    and drag "Custom Menu" widget and drop it in the Primary widget area.
    You have to select different menu for different pages from select menu option of the custom menu widget.
    Gourav Shrivastava
