Is there a color chart with the names and codes of all colors for the BlackBird Theme? I'd like the different variations of colors and their codes to make better design selections. Thanks!
It require lot of customization with the theme. Blackbird theme comes with 10 different colors you can use those colors.
For color values visit link given below. http://www.w3schools.com/cssref/css_colornames.asp Follow process given below, if you want to change existing color code of the theme Go to the Theme directory > css > color And edit any one of the color css (for eg. blue.css) and add your color values in place of current values.
You will not get theme directory in your dashboard. You can edit file through FTP. Open your Theme directory (through FTP) Download specific file that you want to edit from there, Edit it, Then again upload it.
