Color option not listed in demo.
Discussion in 'Woodpecker WordPress Business Theme' started by proapc, Jan 2, 2014.
  1. proapc
    proapc Member
    Hailey, Idaho
    I'm currently using several of your themes.
    I would like to use the color selection currently used on http://ProAPC.com
    Can you add that to the theme options?
    It is not possible for us to add new color scheme option in the theme options panel of dashboard,
    but you can edit the any existing color of the color scheme through the process given below.
    Firstly, go to the Appearance -> Theme Options -> Styling Options panel in your dashboard
    and select the pink color scheme from the Theme Stylesheet section.
    And then go to the Theme directory >css directory> color directory > pink.css file and edit pink.css file as instructed in the image given below.
    See the link for reference.
    http://www.inkthemes.com/how-to-edit-internal-files-through-ftp/07/
    I hope this will help you.
