Color Theme for Slider
Discussion in 'Compass WordPress Theme' started by dwhitney, Jun 9, 2016.
  1. dwhitney
    dwhitney New Member
    I was able to change theme for the site using CSS, but the icons and buttons on the slider still use the default colors. Is there another line of code I need to add to change the theme of the slider?
