www.deals407.com >> ALERTS on Menu -- also REQUEST (drop-down from ALERTS I uploaded Contact Form 7 plug-in I made new form (displayed on REQUEST) doesn't work!! Can a phone number REQUIRED field be added to your CONTACT TEMPLATE ???
Hello, I have checked your website and seems that Contact Form 7 plug-in is working fine on your site. If you want to make Your Contact Form Better On Your Website, You can use "formget-contact-form" plugin, which will help you to make your contact form easy and simple. Download it from the link given below. http://wordpress.org/plugins/formget-contact-form/ You just need to register on FormGet, create your form by clicking on the fields and embed the code on your website at any page, post or widget. You can easily place the contact form on every page of your website which will increase the user interaction. You will be able to manage entire communication from a single place between you and your visitor. It will be easy for you to provide support, feedback to your users. We recommend you to try this new contact form solution on your website. Hope it will meet your requirements. You can easily replace the existing contact form with this new one. Let us know your feedback
