Colorway Change Menu Color Tabs and Background?
Discussion in 'ColorWay WordPress Theme' started by irissalmins, Oct 25, 2012.
  1. irissalmins
    irissalmins Member
    Can the background color of the navigation menu area and the color of the tabs be changed?
    Paste this code in Custom CSS
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover, #menu li.current_page_item a {
    background:red!important;
    Inplace of "red" put your color value.
  3. irissalmins
    irissalmins Member
    Thanks! That worked great for the tabs. What about the background of the menu area?
  4. Gourav
    #menu .ddsmoothmenu {
    background: green;
    Inplace of "green" put your color value.
  5. irissalmins
    irissalmins Member
    Thanks.
    Worked great!
    Is there a way to make the entire menu area that new background color? How would I change the font color?
  6. Harmeet
    Harmeet Support Staff
    Put the following code in custom css
    Appearance -> theme options -> styling options -> custom css
    .header .menu-bar {
    background: black;
    This code will change the color of the menu background.
    #menu li a {
    color: red;
    #menu li.current-menu-item a:hover, #menu li.current-menu-parent a:hover, #menu li.current_page_parent a:hover, #menu li a:hover.selected, #menu li.current_page_item a{
    color: red;
    color: red;
    This code is to change the text color, you can change the color value according to your requirement.
    This will solve your problem.
    Thanks.
  7. irissalmins
    irissalmins Member
    You guys are great! I appreciate y'all so much!
