Colorway Mobile Theme Not working
Discussion in 'InkThemes-Support Working Hours' started by belleconsult, Aug 27, 2015.
  1. belleconsult
    belleconsult New Member
    Hi
    I have the Colorway theme on my wordpress site. www.theworkplaceadvisor.com and unfortunately the mobile theme is going to just the blog posts. It doesn't look like it used with the home page as the mobile theme. I have updated all things needing updates. Can you please advise.
    It seems that you are using some plugins and due to that plugins you are facing this problem..
    So please use your themes after deactivating all the plugins from your side once.
    Inkthemes.com
