Colorway Pro Homepage Blog Feature
Discussion in 'ColorWay WordPress Theme' started by chrisdawes, Jul 5, 2017.
  1. chrisdawes
    chrisdawes New Member
    Have set the Homepage Blog Feature to "on" but a post will only appear on the homepage if there is a "featured image" set for a post - if no post has a featured image then no post appears on the homepage....correct? http://470.36d.myftpupload.com
  2. akbar92
    Yes, this is correct, it needs at least one image in the content or feature,
    Hope you are using updated version of the theme, if you are not using the updated version then you have to upgrade the theme, you can get the updated theme files from the member account.
    To upgrade the theme, you have to first delete the older theme from your dashboard and do a fresh installation.
    Note: - Please create a backup of your website before upgrading the theme.
    Akbar
