Hi there. I'm trying to get the Simple Social Icons plugin to work with the Colorway Pro theme. I'm usually pretty good at tweaking the styles, but I just can't get this one to work. I would really appreciate some help with the css on this one. When I add and configure the Simple Social Icons widget, all I get are empty bullets in the sidebar. How do I get the correct styles to be applied? http://nouraknowsbest.com/category/the-barbie/
Hello, We have checked your website and it is working fine, I think it is a cache issue, So please check your website in another browser and clear your system cache.This will solve your issue. Thanks & Regards Gourav Shrivastava
ummm.... what you're saying is not possible - I removed the widget until I heard back from you... There are 2 icons showing but they are nothing more than hard-coded links.
Hello, Social icons are visible at my side. I think you have resolved issue by yourself. Please contact again for further queries. Thanks & Regards Nitesh Raghuwanshi
