Colorway Pro Static Front Page not mobile friendly
Discussion in 'General InkThemes Discussion and Feedback' started by dkuhl, Sep 24, 2017.
  1. dkuhl
    dkuhl New Member
    Hi there, i have used this theme on several sites and have never had a problem before. On my new website however the static front page is not showing correctly on a mobile device, please can you help? My website is www.vertebralbodytethering.co.uk.
    Manythanks.
  2. akbar92
    I have just checked your website but didn't notice the issue as you mentioned above.
    Akbar
