Colorway with Ultimate Product Catalog showing popup using Fancybox
Discussion in 'ColorWay WordPress Theme' started by nexnexy, Mar 11, 2015.
  1. nexnexy
    nexnexy Guest
    Tokyo
    Hi
    Thank you very much for your support!
    I am now trying to setup a demo site:
    http://testgnss.nexnexy.com
    I am using Ultimate Product Catalog showing popup using Fancybox and it does not work properly.
    Please let me know workaround.
  2. ankurjain
    ankurjain Support Staff
    Hello nexnexy,
    It seems it is your plugin related issue ,
    also we are unable to access your site because you have applied some authentication on your site.
    Kindly contact your fancyBox plugin author first .
    Ankur Jain
  3. nexnexy
    nexnexy Guest
    Tokyo
    Hi Ankur,
    Thanks! I have used Easy FancyBox, the workaround and the problem was solved.
    best regards,
