Even on this support forum you suggest copying the shortcodes from the preview site. Problem is - they are no longer there. Nothing I've tried has created proper columns - is this an issue someone can address please as I need to put columns in my webpage and not being able to use the shortcodes really makes me want to ditch this theme & buy another one that has that functionality. Having them removed from the preview site seems to suggest that they just don't work with this theme - and if so is there a fix in the works to address this or is there another way? Thanks for you time.
Hello, Follow the link given below for the shortcode. http://inkthemes.com/wptheme/blackbird-technology/?page_id=96 See the link for reference. http://www.inkthemes.com/how-to-use-shortcodes-in-themes/02/ I hope this will help you. And also please do let me know in which preview link you have not found shortcode.
Thanks for those shortcodes. Now what I wonder is are they available in any other colors (pref ones that go with my themes built-in color choices - Golden Eagle) and I'm perplexed as why the buttons when used in the columns won't line up??? This is really unnerving as the columns should line up and the buttons too?!?! The link that didn't have the shortcodes was for all the Live Previews that I went to (which is where I was pointed earlier in another discussion on these boards)(http://inkthemes.com/wpthemes/goldeneagle-church/coulmns/) Note: Columns is spelled wrong. And there are MULTIPLE examples, none of them have the column code in them.
Hello, Could you please provide the following information listed below. Thread Link: http://www.inkthemes.com/community/threads/column-shortcodes.6963/#post-26297 Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] We will check and try to resolve your issue.
Hello, Your issue has been resolved. You are not using the column short-code properly that is why you are getting problem, so use the short-code properly and also take help of the blog post which explains how to use code. Then you won't get problem. You can check the link given below. 1. http://govidlets.com/about/new-here/ 2. http://govidlets.com/about/?preview=true&preview_id=2&preview_nonce=aecf34c688
