Columns Not Aligning?
Discussion in 'Compass WordPress Theme' started by andreahw16, Feb 27, 2016.
  1. andreahw16
    andreahw16 Guest
    Wheaton, IL
    I am using short-codes to create columns and in the 3 column code the 3rd column is not lining up. It is shifted down some. I have converted to text format and can not see any code or breaks or items that would cause this? Any insight or help will be greatly appreciated.
    Thank you,
    Hello Andrea,
  3. andreahw16
    andreahw16 Guest
    Wheaton, IL
    So sorry yes it grandmamauds.com
    Hello Andrea,
    a img.alignright {
        margin-top: -21px !important;
    Change the numeric value as per the requirement..
  5. andreahw16
    andreahw16 Guest
    Wheaton, IL
    Hello Priyanka, Thank you that did work! You are probably so tired of me but still have a few tweaks if possible? I am attaching screen shots as well. For some reason the left side padding is more then center and right....I scrolled through the css and did not see anything that would cause this, but I am very new at understanding CSS. It seems like we fix one issue and then it causes another one:) Gets frustrating for sure. Is there something causing the different widths. Also is there away to keep the text in place centered under the image. If you widen the page the type rolls up and to the sides..
    Thank you again for all your help!
    Andrea Screen Shot 2016-02-29 at 6.01.30 PM.png Screen Shot 2016-02-29 at 6.01.42 PM.png
  6. priya
    Hello Andrea,
    It seems that your screenshots are not uploaded successfully....
    Kindly check...
  7. andreahw16
    andreahw16 Guest
    Wheaton, IL
    They are exactly how the site looks. When you increase the size of the window the text scrolls all wacky not remaining centered with the image....
