Columns won't work...
Discussion in 'SwiftRay WordPress Theme' started by mrdesignuk, May 11, 2016.
  1. mrdesignuk
    mrdesignuk New Member
    http://v2.independentcelebrants.com/
    No matter if I use the blackbird-technology for columns or a plugin - the columns won't align next to each other.
    Any help would be much appreciated as I want two columns (preferably two third column then a one third).
    Many thanks
    We are checking this issue at our end and will get back to you ASAP..
  3. mrdesignuk
    Hello Priyanka,
    Any progress with this? Without the columns working the template just won't work out for me or my client.
    Any information on how to rectify this would be greatly appreciated.
    We have already forwarded your issue to the concerned department and as they are busy in some other implemenattion so we will try to pull theme over this isse ASAP and will get back to you soon...
