Comments Box Does Not Appear On Blog Posts
Discussion in 'Traffica WordPress Theme' started by dgaygen, Aug 7, 2016.
Tags:
  1. dgaygen
    dgaygen New Member
    The comments box does not appear on blog posts. All of the settings are correct but it doesn't appear. Can you help me, please?
    Have you configure discussion settings appropriately in Setting option of your dashboard..?
  3. dgaygen
    dgaygen New Member
  4. dgaygen
    dgaygen New Member
    I would like to have a comments box, please. Can you help me?
  5. priya
    Your Website URL:
    WordPress Username:
    Password :
  6. dgaygen
    dgaygen New Member
    Priyanka,
    The problem must be in the theme. Here is how I know. I activated the stock twenty sixteen theme and posted a test comment. It posted normally. When I again activated Traffica Pro the comments box was still not there but a notice appeared at the top of the post that said "1 comment" but that link went nowhere. Does this help you determine the problem?
  7. priya
    Would like to tell you that there is no problem with the theme..so it would be difficult for me to assist you without having any look in your site..
    Please send us your dashboard details at [email protected] so that we can figure out the problem..
