Hi all. Fumbling through my compass theme, I am still trying figure out numerous options. For starters: How do get to the sample entries that are still visible? I want to delete them, as the website is online since I uploaded and installed the theme (had to change my wp settings from protected mode to standard). Thanks, Mark
Hello Mark, Greetings from InkThemes! It seems that you are facing problem to insert your own content in your site... So if I am not wrong with your words...you can easily do it via Theme Option panel (Dashboard=>Appearance=>Theme Option) of your dashboard... Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka. Thanks for your reply. I'll attach a screenshot of the lower part of the first page. Obviously, there is still content visible which I did not put there. How do I get rid of it or change these templates? Thanks, Mark
Thanks for your tipp (screenpresso). I'll attach yet another, better screenshot to explain the problem.
Hello, Please follow the screenshots given below. Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Thanks Priyanka. I've made a little progress. However, now I wonder how to make these testimonials appear on my contact page which I call PORTRAIT on my website. Is there a way to add additional testimonials? Or, perhaps even better: rotate testimonials when a user clicks through the website? I have half a dozen testimonials at hand. Also, I through in a second question in this regard, and I hope you will forgive me, because I am not a programmer: I have successfully worked on my HP bottom feature. Unfortunately, the link does not open in a new window.
Another question regarding the testimonials: I used the suggested measurements (74x72 px). All images seem to be blurred. Should they be in a different size?
How about these images? What size must they be? Obviously, the measurements given in the template are incorrect.
Hello, You can use "Testimonials Slider" plugin to show the testimonial on contact page.. Here's the link of the plugin, please have look... https://wordpress.org/plugins/testimonialslider/.. You just need to paste below code in template_contact.php file under Editor (Dashboard=>Appearance=>Editor) option of your dashboard... PHP: <?php echo do_shortcode('[show_testimonials]'); ?> To add more testimonial under homepage, please follow the link given below.. http://www.inkthemes.com/community/threads/add-testimonials.19732/#post-77768 Note: Add as many testimonials as you want but be careful to assign name for the testimonial as I have done in my screenshots... For your another requirement, i.e. to open button link in a new window. Regarding this, please follow the screenshot given below. For your last issue, i.e. related to the testimonial image.. So would you please try to use 125px*125px image size for once and check after that.... Hope it will resolve your issues...... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Priyanka. I hate to admit it, but I am stuck again! In my dashboard the theme editor does not show. So, I am not able to access the files you propose. I found the following thread. But it did no good for me, although I followed all instructions. I will send you a link to access my WP admin - and hope for the best Thanks, Mark
Hello, For your information, I am using "WP-Editor" plugin to edit files. You can also download and use it from the link https://wordpress.org/plugins/wp-editor/. After activating this plugin, you will get the same screen as shown in the screenshot. Thanks & Regards! Priyanka InkThemes.com
Priyanka, if my email gets through after multiple tries you will find my details to check into my WP dashboard. I already have the WP Editor installed, but the theme editor does not show! Cheers, Mark
