Compass Pro current version
Discussion in 'Compass WordPress Theme' started by computerpros, May 2, 2016.
  1. computerpros
    computerpros Member
    What is the current version of Compass Pro? Is there any updates planned?
    Thank you!
    Latest version of the theme is 1.1.1
    == Changelog ==
    = Theme Name: Compass Theme Pro=
    Version: 1.1.1 =
    1. Added a new feature to the theme. Now its possible to turn off all the animation of the theme.
    We are planning to convert the theme to the bootstrap framework...and going to work on this soon...
    So after releasing next update will notify you the same..
  3. computerpros
    computerpros Member
    Any update on the update?
  4. Naveen
    Hello!
    We haven't converted the theme to Bootstrap framework yet but there is a new version available in the members area with following changelog:
    == Changelog ==
    Version: 1.1.2 =
    1. Woocommerce compatible.
    2. Fixed some style issue.
    3. font-awesome library updated.
    4. Removed all contents with text strings.
    5. Remove unused codes.
    6. Added translation function to text strings.
    From above changelog, you can see the changes done so far.
    If you haven't customized your theme's source code then, you are suggested to download a fresh copy of latest version of this theme from members area and upload it to your website.
    Naveen Kolhe
  5. earnestmarket
    earnestmarket Member
    Hi. I'm using 1.1.2 version of Compass but am getting an error message that the theme does not declare Woocommerce support. How do I fix this?
  6. Naveen
    The theme already comes with WooCommerce compatibility features, if you still getting the notification then, you can share your WordPress admin credentials at [email protected]
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    We will check and do the needful.
    Warm Regards!
    Naveen Kolhe
  7. earnestmarket
    Thank you! I just sent the email.
  8. Naveen
    I am glad to inform you that- Your issue has been fixed, Kindly visit your site and acknowledge us for the same.
    Warm Regards!
    Naveen Kolhe
  9. earnestmarket
    Sorry I didn't get back here. Thank you for getting the fix in for me! It is working great now.
  10. Naveen
    Alright!
