Compass Pro
Discussion in 'Compass WordPress Theme' started by critsey, Feb 17, 2017.
  1. critsey
    critsey New Member
    How do I remove the advertisement toward the bottom, that advertises the theme itself "your site is faster to build...".
    Thanks for any help!
  2. Naveen
    You can either edit the area or turn it off from your Dashboard->InkThemes->Theme Options->Homepage Bottom Feature settings
    Check the attached screenshot.
    Warm Regards!
    Naveen Kolhe
