Hi all. I really like my new Compass Theme - but, as a wp newbie, I am fumbling to set it up in detail For starters: How do I change the effects between images? I want them to smoothly crossfade one into the other. Secondly, can I make adjustments to the visible scoll buttons? Thanks, Mark
Hello Mark, Greetings from InkThemes! Regarding your first issue, Please follow the screenshot given below. And for your second issue, Sorry, I didn't get your issue... So would you please elaborate a bit more along with some edited screenshot so that we can assist you accordingly... If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka. Thanks for your reply. I found the slider tool and have successfully added five images and additional information. But I have not seen a way to control the effect (see here) I want each image to fade into the next one (endless repeat). Is there a tool to do it or will I have to change a command line somewhere? Please advise. Cheers, Mark
Could you please respond to my question? Where & how can I change the effects between slides? Thanks, Mark
Still hoping to receive a helpful answer. I want to use a desolve to change from one image to the next. How can I do that? Mark
Hello, I would like to inform you that we are using slit slider in the theme and there are limited sliding effects for the sliders so I am really sorry to say we can't change sliding effect as per your requirement... Hope you will understand... Thanks & Regards! Priyanka InkThemes.com
That is not helpful, to be honest. My images are optimized for desolves. Why is it not possible to add the easiest effect of all?
hmm. Ok. I got the message. That's bad. Because it means I cannot use the theme as intented. In that case I will have to find another one. One last attempt: Is it possible to integrate the Meteor Slider instead? This template and widget actually gives all the options I am looking for. Curious, Mark
Hello, Mark.. Could you please send us your dashboard details at [email protected] along with this thread link and we will replace the theme slider with your suggested slider i.e. Meteor Slider.. Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi Priya. The email [email protected] does not work, no matter what I try! '[email protected]' am 08.03.2016 16:32 503 Bad sequence of commands
