Compatibility with HideMyWP
Discussion in 'VideoCraft WordPress Theme' started by mar268, Aug 28, 2014.
  1. mar268
    mar268 New Member
    Can you please tell me if Videocraft theme is compatible with HideMyWP plugin? When I installed the plugin and chose "Hide My wp-login.php" option in that plugin, I can get to the login page but the "SignIn" always ends up in 404 page. Is there a way to fix this ?
    Thank you.
    Aravind
  2. Yogesh
    Yogesh Guest
    Unfortunately this theme is not compatible with this plugin, Sorry.
    Contact to plugin author to fix this problem.
    Yogesh Bhade
  3. mar268
    mar268 New Member
  4. Yogesh
    Yogesh Guest
    You have to install it and check it that it is compatible or not.
    Yogesh Bhade
  5. mar268
    mar268 New Member
    Hi Yogesh,
    Ok I will. Can you please tell me how did you conclude that Videocraft theme was not compatible with the HideMyWP plugin ? Did you install and check it or was it from previous experience ?
    Thank you.
  6. Yogesh
    Yogesh Guest
    It's my previous experience.
    Yogesh Bhade
  7. mar268
    mar268 New Member
    Hi Yogesh,
    I contacted the plugin author for HideMyWP plugin about the incompatibility and he gave the following reply.
    The problem is that your theme use plain text (wp-login.php) rather than standard WP login function (wp_login_url())
    To fix this you should contact with theme author.
    Is it a change you can do ?
    Thank you.
