Constant Contact integration issue
Discussion in 'Popup Ninja WordPress Plugin' started by withimpact, Jun 4, 2014.
  1. withimpact
    withimpact Guest
    I am trying to set up popup ninja and when I try to integrate with Constant Contact, the initial form fails with the following:
    OAuth Exception: Username withimpact not found in datastore Click here to authorize
    Upon trying it at CC, I get the following message:
    The provided request token to authorize must be valid.
    Please close the window to return to you application.
    I cleared my cookies and I still get the same message. I also confirmed I'm using the right username and password. Help please. Thanks!
  2. withimpact
    withimpact Guest
    I have actually tried several hacks... including entering my API key into the mailing_list view... that didn't work.
    Please help. I'm at a dead end. Thanks.
  3. csdmpurchasing
    csdmpurchasing New Member
    I'm having this same issue, being this never got a reply that I can see I will be disputing this charge in the morning.
  4. Yogesh
    Yogesh Guest
  5. Yogesh
    Yogesh Guest
    We are working on your issue and we need your FTP details so please provide us your FTP details at [email protected].
    Yogesh Bhade
