Contact template and right hand side widgets
Discussion in 'Woodpecker WordPress Business Theme' started by coachkelly, Jul 28, 2015.
  1. coachkelly
    coachkelly Member
    I am using the contact template for my Contact Me page. But I cannot find anyplace when I choose that option to edit the page to get rid of the side widgets. Here is the link
    http://www.wpsweet3.com/lindt/contact-me/
    And I am attaching screen shot of the edit page:
    Thank you in advance for any guidance!
  2. praveen
    praveen Support Staff
  3. coachkelly
    coachkelly Member
    Praveen, thank you. Unfortunately, I cannot get any sound with the link you provided. I tried listening on multiple computers and with multiple browsers, but am not able to hear anything. I can see fine, but do need the sound. Would you please redo? Thank you!
    Take care,
    Kelly
  4. praveen
    Hey Kelly,
    My apologies....
    Actually the video doesn't contain any sound element....it's only a video.
    But the video has clear steps to follow.
    I think the problem is that you don't get theme editor option in the Appearance of the WordPress dashboard and also don't see the files to edit.
    Don't worry!!!
    Actually, I am using "WP-Editor" plugin to edit files.
    After activating this plugin, you will get the same screen as shown in the video.
    Hope it will be helpful to you :)
    Let me know if need further help.
    Praveen
  5. coachkelly
    coachkelly Member
    Praveen,
    That is AWESOME! Thank you so much for your help, I really appreciate it! That worked perfectly and looks great. (and yes, as I watched the video again, I didn't need any sound).
    I have another question, but I will put it in another posting...
    Thanks again!
    Take care,
    Kelly
  6. praveen
    Hi Kelly,
    It's nice to assist you :)
    Hope you are enjoying InkTheme services.
    Do let me know if you need any help.
    Praveen
  7. revonwebsites
    revonwebsites New Member
    Is it possible to renew the link for this instruction video?
    A lot of instruction video's aren't 'found' anymore.
  8. priya
    You can follow the screenshots given below.
    Hope you will find it helpful..
