Contact US settings
Discussion in 'Compass WordPress Theme' started by computerpros, Jan 11, 2016.
  1. computerpros
    computerpros Member
    Where can I edit the info for the Contact Us page. The only thing I have been able to do is add the map, but I do not see where to edit the email address to where the "Submit Message" goes. Also, is there a way to add a phone number to this page?
    To add phone no, you just need to follow the screenshots given below.
    Code is as follow...
        <input type="text" id="contactName" name="Phone_no"  value="<?php if (isset($_POST['Phone_no']))
                    echo $_POST['Phone_no']; ?>" class="required requiredField" placeholder="<?php echo Phone_no; ?>" required/>
                    <?php if ($nameError != '') { ?>
            <span class="error"> <?php echo $nameError; ?> </span>
        <?php } ?>
      if (trim($_POST['Phone_no']) === '') {
            $nameError = 'Please enter your phone no.';
            $hasError = true;
        } else {
            $name = trim($_POST['Phone_no']);
  3. computerpros
    computerpros Member
    Can I input this code anywhere within the template_contact.php or does it need to be in a specific spot or replace something else listed in the template?
    Question: You stated: "After activating this plugin, you will get the same screen as shown in the screenshot. " I do not see the screen shot you mention.
    You need to put the code at the same place as I have mentioned in my screenshot like line no: 27 and 92.
    And after activating the plugin, Go through template_contact.php page (Dashboard=>Appearance=>Theme Editor) and then you will get the same screen..
    Hope you will find it helpful..
