container "box shadow" question
Discussion in 'ColorWay WordPress Theme' started by chauncey99, Jan 9, 2014.
  1. chauncey99
    chauncey99 Member
    Hello, I would like for the container box shadow to continue down and around the footer instead of stopping at the bottom of the main content.
    If I use this code:
    .container {
    box-shadow: none ! important;
    the box shadow disappears completely.
    Instead, I would prefer for the box shadow to continue around the footer, instead of making a line across the bottom of the main content.
    Is this possible?
    If not, is it possible to eliminate the bottom of the box shadow (top and sides of box shadow remain)?
    Thank you for your help.
  3. chauncey99
    chauncey99 Member
  4. Piyush
    .footer-container {
    box-shadow: inset 0 0 1px #000000;
    .footer-navi {
