Content Stats Pro Plugin
Discussion in 'Content Stats WordPress Plugin' started by tcg007, Sep 15, 2015.
  1. tcg007
    tcg007 Member
    The zip file in the download area for the Content Stats Pro plugin is empty. Please check by profile area.
  2. nitin
    nitin Guest
    After your concern, I have checked it again in the profile area and found everything running properly. For your reference we have provided you a video also. Please follow the video link given below: -
    http://screenpresso.com/=tJA5d
    Kindly check it again.
    If you are still with the issue, please let me know.
    Nitin
  3. tcg007
    tcg007 Member
    Thanks for your video. The zip file is only 10KB big. The install does not work.
    There are missing files....I think.
    See my attached snapshot.
  4. nitin
    nitin Guest
    I would like to inform you that although the .zip file is of merely 10KB, but the extracted folder contains all the necessary files for the plugin to work. It seems that you have not extracted the .zip file properly.
    No issue. We are always here to help you and to save your time as well. And this time, we are going to do it for you. So, send us your website WordPress login details at [email protected] along with the thread link.
    We will fix the issue taking the least possible time.
    Nitin
