Copy & Paste
Discussion in 'GeoCraft WordPress Theme' started by citified, May 19, 2013.
  1. citified
    citified Guest
    Is it possible to Copy & Paste a geocraft completed theme. So if I want all geocraft themes linked together how would/could I copy one site and add just a different name to it. All the categories would be the same. Is this possible?
  2. gosmartmobi
    gosmartmobi Member
    Check threads on import and export cvs. - from forum member
  3. Nitesh
  4. anto
    anto Member
    Hello Nitesh,
    I've tried Duplicator to create a package by clicking the Create Package button at the top of the Duplicator Screen.
    Normally the phrase "Click Create Package Set" must appear on the message box to confirm package creation.
    But it does not work, because the phrase "Click Create Package Set" does not appear with Geocraft (it appears with Twenty Twelve theme though).
    Could you please kindly help?
    (I'm sending you my login by PM, please kindly check the conservation. Thanks)
    Thanks a lot.
    Anto
  5. Nitesh
    Hello Anto,
    Plugins css is conflicting with Geocraft theme that's why "Create package button" is not clearly visible but it is working correctly.
    Please check image below. Click first button as shown in the image. It will work.
    anto likes this.
  6. anto
    anto Member
    Thank you so much, Nitesh.
    Your help is precious to me.
    Nice week-end!
