Copyright Info
Discussion in 'Local Business WordPress Theme' started by 1stopnonprofitshop, Jan 28, 2015.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Website: www.1stopnonprofitshop.com
    I went into Theme Options--Footer Text and typed in the Copyright Info I want displayed. The text that I have in the footer box is not showing up...all that shows is what I had before. I'm not sure where I even put that info that I have in now...as I can't find it to delete it. I tried emptying the Cache and it still is not working. How do I get the info that I have in the footer box to show up on the website?
    This is what I have in the footer box: © 2015 1 Stop Nonprofit Shop, All Rights Reserved
  2. Pramod
    Pramod Guest
  3. 1stopnonprofitshop
  4. sunilku
    sunilku New Member
    Hi there, I ran into a similar issue, the left site of the footer that you are seeing is your site title and tag line. You can change it in setting>>general.
    If the site title and tag line are long then it overwrites the right side of the footer. Hope that works.
  5. Pramod
    Pramod Guest
    .copyrightinfo {
    display:block;
    Theme options text will be for right bottom corner.
    Also follow sunilku instructions to change left footer area.
    Pramod
  6. 1stopnonprofitshop
  7. praveen
    praveen Support Staff
    Praveen
  8. 1stopnonprofitshop
    It did...thanks! Is there anyway to get rid of the 1 Stop Nonprofit Shop- on the left side of the footer? I tried to remove it from the "Site Title" in settings, but then it also removed it from the top tab where it shows the name of the site.
  9. praveen
    .copyright_left {
    Praveen
