Hi there! Will it be possible to show for instance the H1, H2 & H3 tags as excerpt in the blog post overview instead og the default excerpt? If no - Can you help me with an alternative solution so I can show some custom text in the blog post overview? http://superleg.dk/produkter/boern-og-unge/ Thanks!
Hello, For this, you can search any excerpt plugin from WordPress.org and upload it. http://wordpress.org/plugins Thanks & Regards Gourav Shrivastava
