Country and Provinces connection are Inconsistent #2
Discussion in 'ClassiCraft WordPress Theme' started by brainartist, Nov 10, 2015.
  1. brainartist
    brainartist New Member
    Hello.
    I got the same problem as cromarts2014 in this thread.
    Pramod provided a picture on which the solution seemed to be displayed.
    At the page "Post an Ad" and at the "Edit Ad" page, whatever I choose for the country, the states remain the same: The states of Amercia.
    What do I have to do, in order to get the state select field changed to the particular country?
    Kindly regards
    I would like to suggest you to download the latest version of the theme from the members area in which we have already updated this feature.
    You just need to enable Advance Location Field from the Custom Field (Setting=>Advance Setting=>Custom Field=>Advance Location Field) of your dashboard.
    Here is screenshot given below, please have a look..
  3. brainartist
    Hello, Priyanka.
    Thanks, I will do that.
    But I'm afraid of doing all the translation again.
    In your templates you echo constants, like "<?php echo AD_TITLE; ?>", but in order to work with my .po file I have to change this part into "<?php _e(AD_TITLE, THEME_SLUG); ?>
    Hope I will not need to translate everything again.
    Kindly regards
  4. brainartist
    Yep, I need to translate everything again.
    I hoped that deleting of an image in the edit ad section does now work, but it still doesn't.
    Furthermore the text "Remove" is shown right behind the round delete button.
    Deleting in the WordPress dashboard is working :-/.
    Maybe I can use the code for the region, country and state and use it at my version.
    I think I will stay at my rather working version because I don't know what isn't working, too.
    Kindly regards
  5. brainartist
    Checking the box at "Advance Location Field" does indeed solve the problem.
  6. priya
    Sounds good that your problem has been resolved..
