Hi There is a lot of white space on my website hellenisticvedicastrology.com so I was wondering if it is possible to create a boxed layout using Harrington Theme but instead of a solid colour I was hoping to use a lotus design. Hope this makes sense! Look forward to hearing from you. Kind regards Fiona
Hi, It would be better to understand your requirement through some edited screenshots. If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Regards! Praveen InkThemes.com
Hi Praveen I have attached a screenshot for you. It is not the right design but it might better explain what I am trying to achieve. Basically the design will form a box around the content on the page, creating a box layout. Hope this helps. Regards Fiona
Greetings from InkThemes, As per your requirement, I would like to inform you that - This will require some source code customization in the theme which is time-consuming and would be done specially for you by our team. As InkThemes has been receiving a high volume of support requests. Therefore, there will be some charges for the customization based on your requirements.. - Analysis: To provide a box layout design for the content of your webpage. - What we are going to do? : Altering the HTML and CSS files to include the images as the box layout, and to partition and set up the grids accordingly. - Milestones/Timeline: We will deliver the customization within 2-3 working days. - Customization Charge and Payment mode: As per InkThemes WordPress themes and plugin customization policy, we charge $15 per hour, Keeping in view your requirement it will take an hour working hrs. Kindly, transfer the payment of $15 directly to our PayPal account. Here is the PayPal id - [email protected] Once you make the payment do share your transaction details.. We will start customization and will try our best to deliver the customized work in above- mentioned timeline.. We will require following information from your end: WordPress site URL: WordPress username: WordPress password: FTP details: FTP host URL: FTP username: FTP password: Waiting for your confirmation.. Customer satisfaction is our first priority.. Thanks & Regards! Nitin InkThemes.com
