CSS Styling using child theme
Discussion in 'GeoCraft WordPress Theme' started by 4144diane, May 11, 2016.
  1. 4144diane
    4144diane New Member
    Tavistock, Devon. United Kingdom
    Hello
    Just a quick question, I would like to make minor changes to a little bit of styling on my website. See screenshot attached.
    Basically there is a bar behind the tabs that has a gradient grey on it, I would like to remove this and any borders that is has also, leaving it just white behind the tabs. I hadn't noticed this bar previously and wondered if it had anything to do with a plugin that I had installed 'Custom Contact Forms'.
    Is there a little bit of css that I can either add to my child theme or change in the editor to remove this.
    This is the bit of code that it falls within, but I can't work out which id / class is controlling this element:
    <ul class="tabnav ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all" role="tablist">
    Thanking you in advance for your help.
    Kind regards
    Diane
  2. 4144diane
    Is it somewhere within this that needs alterations in the main 'style.css'?
    .tabbed .tabnav li {
    display: inline-block;
    list-style: none;
    padding-right: 5px;
    position: relative;
    z-index: 0;
    .tabbed .tabnav li a {
    text-decoration: none;
    font-size: 16px;
    color: #444;
    padding: 14px 17px;
    border: 1px solid #d6d6d6;
    background: #f7f6f7;
    background: -webkit-gradient(linear, left top, left bottom, from(#f7f6f7), to(#dfdbdf));
    background: -webkit-linear-gradient(#f7f6f7, #dfdbdf);
    background: -moz-linear-gradient(center top, #f7f6f7 0%, #dfdbdf 100%);
    background: -moz-gradient(center top, #f7f6f7 0%, #dfdbdf 100%);
    outline: none;
    border-bottom: none;
    margin-bottom: -3px;
    margin-right: 0;
    text-shadow: 0 1px 0 rgba(255, 255, 255, 0.8);
    Many thanks
    Diane
  3. priya
    Hello, Diane..
    Done the changes in your site..
    Kindly check your site..
