Custom Circle distortion
Discussion in 'ButterBelly WordPress Theme' started by kellyzollo, Oct 21, 2015.
  1. kellyzollo
    kellyzollo New Member
    I have a client that has been using this site for over a year and why have tried to update the circles every few months with the required sizing for images. When we upload the images they are stretchy and distorted is there a way to fix this? Is there a .psd file I am missing?
    Thank you,
    Kelly
  2. nitin
    nitin Guest
    Hi Kelly,
    Hope you are doing good.
    It seems that you are concerned about the circle images of feature area. If so, I would like to inform you that this distortion/stretchy image problem arises when we upload images of improper dimensions.
    The recommended size for the image for those circles is (143 x 143) pixels.
    If you will upload the image as per the standards, you will feel your issue resolved.
    Hope this helps.
    Nitin
