Custom colored buttons
Discussion in 'Themia WordPress Theme' started by maes39, Dec 26, 2014.
  1. maes39
    maes39 Member
    On my website www.timstaaldesign.nl i want to make custom colored buttons.
    Can you tell me how to make these buttons??
    I want to change the color to #a43517.
    Can you help me??
  2. Pramod
    Pramod Guest
    Please explain little bit more.
    Which type of buttons and where you want to use it ?
    Pramod
  3. maes39
    maes39 Member
    I meant the buttons of the main navigation (see attached file).
    And then the rollover color.
  4. Pramod
    Pramod Guest
    You can change the color of menu by below css code.
    More than this you cannot change.
    #menu li,#menu li a{
    background: none;
    #menu li.current-menu-item, #menu li.current-menu-parent, #menu li.current_page_parent, #menu li:hover, #menu li.current_page_item {
    background: none;
    background: #a43517;
    border-radius: 15px;
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li:hover a, #menu li a.selected, #menu li a:hover, #menu li.current_page_item a {
    color: #fff;
    background: url('images/nav-orange.png') no-repeat 100% -124px;
    background: none;
    #menu li a {
    text-shadow: none;
    color: white;
    padding-left: 13px;
    padding-right: 13px;
    #menu li a:hover {
    #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover, #menu li.current_page_item a {
    margin: 0;
    margin-left: 10px;
    padding-left: 13px;
    padding-top: 4px;
    padding-bottom: 5px;
    color: #FFF;
    text-shadow: none;
    Pramod
  5. maes39
    maes39 Member
    Hello Pramod,
    Is it possible to change one theme stylesheet into my color so the buttons in the main menu have the right color??
    I don't use black so i want to change this one.
  6. Pramod
    Pramod Guest
    Menu has images for background and it required images for your required color.
    We will try to give you solution.
    Pramod
