Custom fields navigation- a way to improve it!
Discussion in 'GeoCraft WordPress Theme' started by rogerb, Jan 4, 2013.
  1. rogerb
    rogerb Active Member
    Now that we have to use the custom fields to set up our system as we want it could the navigation be made better?
    For instance Select a field to edit, edit, save, navigate back to custom fields, select another etc is a real pain! You have to look carefully to make sure which field you are actually editing.
    Why not have the same technique you use for setting the theme options with the field names vertically on the left and the detail on the right for editing when a field name is clicked. So much more logical - after all you already use this technique to such good effect!
    Would be nice if you would consider this for your theme users.
    Roger B
  2. rogerb
    Anybody else have a view on this as I find it an difficult and cumbersome way of doing things and could be much improved for us all.
  3. rogerb
    Anybody else have a view on this - speak up if you think its a good idea to help us all !
