Hello, After installing the 1.8.2 updates, I'm having problems adding a custom field. It does add on the backend but not showing on the frontend and yes it was active. Also, the custom fields still showing on frontend even when they are deactivated. Im also unable to have them change the order in which they appear on the frontend. Thanks
Hello, I think it is a cache issue, So please check your website in another browser and clear your system cache.This will solve your issue. If not then, Please provide the following information listed below. Thread Link: Your Website URL: WordPress Username: WordPress Password: Send this information on our email at [email protected] I will check your issue. Thanks & Regards Gourav Shrivastava
