Custom Fields
Discussion in 'GeoCraft WordPress Theme' started by canet428, May 13, 2015.
  1. canet428
    canet428 Guest
    Is it possible to add "video" to the drop down field type for custom fields?
    I'd like to have a video where the slider is currently and a smaller slider below the video, above the detailed text.
  2. sameerwalkar
    sameerwalkar Guest
    I got your concern. But as if now the mentioned feature is not available.
    Alternatively what you can do is you can add an iframe code in the "text area" field type description part, that will make the video appear in the detailed listing page.
    Also, you can only use the embed code in that text area section.
    Hope you have understand my concern.
    Let me know for further doubts.
