Custom Header Background Graphic
Discussion in 'Local Business WordPress Theme' started by ninjainktheme, Jul 15, 2013.
  1. ninjainktheme
    ninjainktheme New Member
    I have read through the forum and got the code that was suggested to put in the cystom css box under style options. However fter putting in the code to change the header background all I get is a white background where the header background should be. Please help! This is the code I am using.
    .header{
    background:none;
    background-image:url('http://bestsacramentopatiocovers.com/wp-content/uploads/2013/07/headerbg.png');
    We have checked this code in our side, it is working fine with the Local Bussiness Theme.
    You can also try the code given below, paste it in Custom CSS
    .header{
    background:none;
    background-image:url('http://bestsacramentopatiocovers.com/wp-content/uploads/2013/07/headerbg.png') ! important;
    This will solve your issue, if not, could you please provide the following information listed below.
    Thread Link: http://www.inkthemes.com/community/threads/custom-header-background-graphic.6046/
    Your Website URL:
    WordPress Username:
    WordPress Password:
    We will check and try to resolve your issue.
  3. ninjainktheme
    Hi , it still did not work the background is still coming out white. I have emailed the information you asked for. Thank you in advance... Leon
  4. ninjainktheme
    Question, does the header graphic need to be a certain size to work? And if so what is that size?
  5. Piyush
  6. ninjainktheme
    What size should the header be?
  7. Piyush
    You can use 952 x 210 pixels (i.e. width: 952px and height: 210px) dimension of image for your header background, it will look fine.
  8. ninjainktheme
