Custom language settings form
Discussion in 'InkAppointment WordPress Plugin' started by joudejans, Jun 27, 2015.
  1. joudejans
    joudejans Guest
    I'm looking for the settings in the form field, to change the input field names or placeholder to match the sites language. Where can i change these?
    Thank you,
    Jasper
  2. praveen
    praveen Support Staff
    Hello, Jasper!
    Praveen
  3. joudejans
    joudejans Guest
    I deactivated all plugins to be sure but i'm not getting the plugin editor- option.. I can't find it anywhere.
    I have the dutch version but you can believe me when i say the only options are "installed plugins" or "new plugin
    Forums just say "deactivate" but that doesn't help..
  4. praveen
    Hello, Jasper!
    There is no need to worry!!!
    Please send us your website WordPress login details at [email protected] along with the thread link.
    We will install the "WP-Editor" plugin in your WordPress dashboard and then you will be able to edit the theme files.
    Praveen
