Hi Inktheme team, In our "Infoway" theme we can no longer add new fieldnames using the Customs Leads Capture Form. After entering a fieldname en select a field type we press the clickable blue "Add Field" button, but it does not confirm the changes by showing the required fields. Can you please assist with a solution? Frits Stel, Netherlands
Hello Frits, Greetings from InkThemes! To determine and fix the issue, we need to access your dashboard. So, send us your website WordPress login details at [email protected] along with the thread link. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, Thanks for your support. An e-mail massage has been send your way. Just waiting for your instructions and reply. Thanks! Best Regards, Frits
Hello, Frits.. I have sent you an email... Kindly check your email.. Thanks & Regards! Priyanka InkThemes.com
Hello InkThemes Team! I experienced the same situation as Frits. I was trying to add "country" as a radio button (US / Philippines). Then it didn't show up on the list of fields. So, I tried it again. Now I have the text "Country" (two of them) showing on the form. I've attached an image. Please help! Looking forward to your response and support Thank you, Cherry
Hi, Cherry.. Would you please reinstall fresh copy of the theme from the members area..? Hope it will resolve your issue Thanks & Regards! Priyanka InkThemes.com
Hi Priyanka, I did what you suggested and I'm still not able to delete the field names of the radio button fields I added. I deactivated my Lead Captures Form for now until this is resolved as it is displaying those unwanted field names. I would appreciated some help. Looking forward to your response. Thanks, ~ Cherry
Hello, Please send us your dashboard details at [email protected] along with the thread link so that we can figure out the issue and able to resolve that. Your Website URL: WordPress Username: Password : Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
