Custom Post Type Loop Explanation, and Possibly Help?
Discussion in 'GeoCraft WordPress Theme' started by kentoliver, Mar 19, 2013.
  1. kentoliver
    kentoliver Active Member
    Hey there InkThemes,
    I see that there is a way to search and filter the contractor listings. I was wondering if you could help me solve a problem with some functionality I am trying to implement into this theme.
    Say I have a string holding a variable:
    $my_string = 'DESC';
    Can I display the loop of contractors to display in descending order? Or better yet to display using a string passed through by input fields? Essentially I am trying to create a filter for the contractors, so that after the user searches. They have the option to view ascending order, descending order, and by id, and perhaps some other things I am thinking of.
    That sounded a bit confusing. Really I am trying to figure out how to display the contractor loop, in a different way other then by most recent.
    Once I figure out how the Custom Post Type is being called, I can figure out the rest myself.
    Thanks!
    Can you please tell us the link of your website.
    Is this "contractor" a category ?
  3. kentoliver
    I am sorry the Contractor is just the listing custom post type. Forget the word contractor, and focus on the listing part.
    I am trying to figure out how I can display the list of listings in a different order then just Recently Added.
    Ideally I am adding a Filter functionality, where the user can change the list of contractors on the homepage.
    So my thought process is pretty much using a similar one to your search-loop functionality, where there is a string holding the sort type, then to call it with issets and inputs.
    I am working on a test site, and I will share with the InkThemes community once it is ready for launch.
    However if the test site is needed to understand what I am trying to convey, then that is not a problem.
    -Kent Oliver
  4. kentoliver
  5. Gourav
    We have created the loop in a way that if there are any sticky listings they appear on the top.
    If no listings are marked as sticky, they are shown in the Recently added fashion.
    If you want to customize the query in anyways, you can do so from the front-page.php file, you can sort the listings in descending ways as required.
    Check the screenshot below.
    http://screencast.com/t/ZhC7HvEOWb
    Similarly if you have any Sticky listings, you can order them through the code in the same file few lines above.
    kentoliver likes this.
  6. kentoliver
    Thanks so much Gourav for the screenshot.
    I will let you know if I figure out the click-sort functionality.
    All the best,
    -Kent
  7. kentoliver
    Hey again,
    I added that line of code, however it does not look to change the outcome at all...
    query_posts(array(
    'post__in' => $sticky,
    'ignore_sticky_posts' => 1,
    'post_type' => $post_type,
    'showposts' => $limit,
    'paged' => $paged,
    'order' => 'DESC'
    I tried multiple SQL sorting syntax, and all turned out the same.
  8. aliounn
    aliounn Member
    Hi Kentoliver,
    your web site looks very nice ! good job
    how did you add the big home page slider ? i like it
  9. kentoliver
    Hey there aliounn
    All I did was break the wrapper to get the 100%, then i re-made it, and then its just a slider plugin.
    I believe the plugin is called:
    uBillboard
  10. kentoliver
    Found the solution. I just pasted the code in the sticky part by mistake ><
    Thanks again Gourav!
  11. kentoliver
    Now if you know of how to make it sort randomly. You have my project all wrapped up :p
    any tips from anyone on making the posts sort randomly would be greatly appreciated.
  12. kentoliver
    Found my own solution.
    instead of using:
    'order' => 'rand'
    i tried:
    'orderby' => 'rand'
    And it works. Now to create the ifs and buts and then I will be home free.
    Thanks again for all the help. Solid support forum.
    Krish likes this.
  13. kentoliver
    if anyone wants to randomize the featured slider. this is how i accomplished it:
    <?php
    $count = 1;
    $class = '';
    $check = false;
    query_posts(array(
    'post_type' => POST_TYPE,
    'showposts' => 500,
    'orderby' => 'rand',
    'meta_query' => array(
    array(
    'key' => 'geocraft_f_checkbox1',
    'value' => 'on',
    'compare' => 'NOT NULL',
    if (have_posts()) :
    Krish likes this.
  14. aliounn
    aliounn Member
    Thank you very much for all your posts
  15. Krish
    Krish Support Staff
    India
    Your website looks really great with all the customizations. Cheers.
    Krish
  16. kentoliver
    Thanks alot Krish!
    Has taken up a bit of my time ;)
