Custom theme color
Discussion in 'Subscribely v2 WordPress Theme' started by deveshd, Sep 13, 2014.
  1. deveshd
    deveshd Member
    How do I use my own color instead of using one of the styling themes available? For example, http://www.neerajagarwal.net is built on subscribely but it is using it's own custom blue and not one of the default theme colours? Please let me know.
  2. Pramod
    Pramod Guest
    You have option to change the theme color from your dashboard theme option section.
    Pramod
  3. deveshd
    deveshd Member
    Please read the thread again, I do not want one of the default options, I want to have my own colour theme, where do I customize that?
  4. Pramod
    Pramod Guest
    OK, Please specify sections with color and screenshots.
    As well as URL of your Website.
    Pramod
  5. deveshd
    deveshd Member
    Hi, here is the details:
    URL: http://webworxworld.com/client-demo5/
    All the sections and buttons that pick the color based on theme selected in Styling area of theme options - buttons, slider background, footer, etc. - See screenshot attached.
  6. Pramod
    Pramod Guest
    div#slider_wrapper {
    background: red !important;
    div#footer_bottom {
    background: pink !important;
    #slider_wrapper .entry .entry_btn:hover, #respond input#submit
    background: blue !important;
    #slider_wrapper .entry .entry_btn:hover, #respond input#submit:hover
    background: yellow !important;
    #menu li.current_page_item a, #menu li.current-menu-item a, #menu li.current-menu-parent a, #menu li.current_page_parent a, #menu li a.selected, #menu li a:hover, #menu .ddsmoothmenu li li:hover a, #menu .ddsmoothmenu li li:hover
    background:green !important;
    Set colors according to your requirement.
    Pramod
  7. deveshd
    deveshd Member
    Works, thanks!
  8. linhnguyen
    linhnguyen Member
    When you go to a page, the header's colour isn' the same as the custome colour.
  9. Pramod
    Pramod Guest
    div#crumbs_wrapper {
    div#header_wrapper {
    background: green !important;
    div#footer_wrapper {
    div#content_wrapper
    Pramod
  10. linhnguyen
    linhnguyen Member
    Perfect, thanks!
